DOOM3 Results of
Gigabyte
GV-NX98X1GHI-B NVIDIA 9800 GX2 Graphics card Benchmarks DOOM 3
In DOOM3, we take a look at the card's performance at default AA/AF and max AA/AF setting of 16xAF/16xAA and at overclock speeds of CPU and GPU core. At default of 3.2GHz and card running at 600/1000 , it scored 207 fps. The score improves to 244 fps when we overclock the CPU to 4GHz. Further increase in the GPU to 720MHz doesn't seem to help, the end result is a dip in frame rate to 241fps. At defaults, when 16xAA/16xAF is applied, the score drops to 142 fps.
