FEAR Benchmark results of Gigabyte
GV-NX98X1GHI-B NVIDIA 9800 GX2 Graphics card
Benchmarks FEAR
In this test, we changed the test method. We tested the card with settings set to 1600x1200, the default will also apply a AF of 4x to the game. At defaults, the card scored 124 fps. Increasing the CPU to 4GHz didn't give a boost in performance, it seems that that is the max can go. As we move the GPU to 720, we get a steady boost to 132 fps. When 16xAA/16xAF is applied to the card at defaults, the frame rate drops to 105fps.
