BIOS Screen shots 1 of ASRock A780GMH/128M AMD 780G+SB710 Mainboard (Review)
Bluetooth 20 March 2008
BIOS 1
The screen shots are taken with board installed with a AM3 X3 710 processor + ASUS Radeon HD 4870X2 EN TOP
CPU Freq ranges 150 ~ 500, PCIe Freq range 75 ~ 250MHz The CPU multiplier that can be adjusted downwards from 13x to 5.5x
CPU voltage can be upped to 1.6375 V NB Freq multiplier can be set to a min of 5 and a max of 10.
NB Voltage can also be adjusted upwards, reaching a high of 1.6375 V Internal graphics mode (using integrated Radeon HD 3200), the graphics can be be speed up if UMA+Sideport is enabled.
G1 - ASRock A780GHM/128M AMD 780G+SB710 Mainboard Review - Introduction
G2 - Mainboard Layout of ASRock A780GHM/128M AMD 780G+SB710 Mainboard Review
G2a - Detail Mainboard Layout of ASRock A780GHM/128M AMD 780G+SB710 Mainboard Review
G3 - Chipsets on board ASRock A780GHM/128M AMD 780G+SB710 Mainboard (Review)
G4 - BIOS Screen shots 1 of ASRock A780GHM/128M AMD 780G+SB710 Mainboard (Review)
G5 - BIOS Screen shots 2 of ASRock A780GHM/128M AMD 780G+SB710 Mainboard (Review)
G6 - BIOS Screen shots 3 of ASRock A780GHM/128M AMD 780G+SB710 Mainboard (Review)
