ASRock X58 SuperComputer Intel X58+ICH10R Core i7
Mainboard Review - Introduction
Introduction
Late last year, Intel launched their latest LGA1366
processors. With the advance of technology, the new processor computes faster
than it's previous generation, the LGA775 Core 2 Quad series of processors. As it is a brand new processor and it has a total different
pinning compared to the previous, ASRock X58 SuperComputer releases it's first
Intel X58 based mainboard supporting the Intel Core i7 920, 940, 965 processors
and system bus up to 6400MT/s and Intel QuickPath Interconnect. Through innovative design, the ASRock X58 SuperComputer
supports a lot more, sometimes even better designed than expensive 1st tier
boards. For better stability, it uses 100% Japanese made high quality
conductive polymer capacitors. Memory wise, it supports
Triple Channel DDR3 2000(OC)/1866(OC)/1600(OC)/1333(OC)/1066 (6 x DIMM slots),
non-ECC, un-buffered memory, Max. capacity up to 24GB and DDR3 ECC, buffered
memory with Intel® Workstation 1S Xeon® processors 3500
series, XMP is also supported. One of the most important design of X58 board is it's PCIe
slots. Some boards have the slots squeezed without considering the air flow and
the length cards blocking the Front panel connectors or SATA ports. On ASRock
X58 SuperComputer it has 4 x PCI Express 2.0 x16
slots (blue @ x8 / x16 mode, orange @ x8 / N/A mode) (Double-wide slot spacing
between each PCI-E slot). Thus you can fit in 2 slot design graphics cards on
all slots.
With the Intel X58 chipset, this board supports multi GPU
designs, namely ATi CrossFire X and NVIDIA SLI. It can support ATI™ CrossFireX™
up to 4 cards Quad CrossFireX™ and NVIDIA® Quad SLI™, 3-Way SLI™ and
SLI™. It also support NVIDIA® Tesla Personal Supercomputer with three
Tesla and one Quadro graphics cards. Some other features on this board include Dual GLan with
Teaming. There are also 6 SATA II ports supporting RAID 0,1,10,5 by ICH10R with
NCQ, AHCI and hotplug. There are 2 SATA II ports that can be used for eSATA
connectors. In additon, 1394 is supported (one port on back panel, one header on
board).
Audio on board is a Realtek 7.1 CH Windows® Vista™ Premium Level HD
Audio with Content Protection, supports DAC with 110dB dynamic range (ALC890
Audio Codec), DTS (Digital Theater Systems) support. This board is environment friendly as it supports the
Intelligent energy saver, helping you to save more energy. Other features on
board include ASRock instant boot, OC tuner for overclocking. The package itself is also comes with the necessary
connectors. They are 2 x ASRock XFire_Bridge_3S Cards, 1 x ASRock SLI Bridge, 1
x ASRock SLI_Bridge_3S Card, 1 x ASRock 3-Way SLI Bridge Card.
