ASRock X58 SuperComputer Intel X58+ICH10R
Core i7 Mainboard
Review - BIOS Screen shots
Bluetooth 13 Feb 2008
BIOS 1
The screen shots are taken with board installed with a Intel Core
i7 965 (3.2GHz).
| Main bios screen shot showing
the CPU used, memory used on board. BIOS is P1.40 |
Under Smart BIOS, you can now
simply load the Performance or Power Saving defaults. The settings are
already optimised for the respective scenarios. You can also use EZ
overclocking to load factory optimised settings for oc speeds or for
DDR3-2000 settings |
| You can load optimised
settings for various functions. In this case, if OK is enter, it will load
parameters best for a DDR3-2000 setting. Note that system may not work with
all RAM and CPUs combinations. |
Over here you can set the CPU
ratio and other settings as shown above |
| For overclock mode, you can
also choose to use I.O.T which sets a percentage to o/c. If you choose
manual, you can adjust the BCLK (def is 133MHz). Optimised is default but
has slightly improvement in speeds with tighter timings in RAM or CPU
parameters. |
QPI Frequency can be set to
operate at 4.8GHz, 5.86GHz or 6.4GHz (default for core i7 965) |
