ASRock (Intel boards) This is a brand new ASRock channel for discussion for Intel boards. |
Future MRT MAP has MOVED here. Click here.
SHARE
Which asrock board are you using right now. ASRock (Intel boards)
09-07-2008, 07:52 PM
Rookie
Potenza rep: 0
4core1600p35-wifi and 4coredual-vsta
18-07-2008, 11:04 AM
The one
Potenza rep: 10
22-07-2008, 02:00 PM
Rookie
Potenza rep: 0
ASRock P45R2000-WIFI
with Q6600@ 3.35ghz
22-07-2008, 03:05 PM
Rookie
Potenza rep: 0
k7s8x, probably will move to p45r2000
05-08-2008, 07:08 AM
Rookie
Potenza rep: 0
4CoreDual-VSTA
19-08-2008, 03:38 AM
Rookie
Potenza rep: 0
P43R1600Twins-Wifi
the review here swung it.
(couldn't get the -110db in the UK, don't use Wifi!)
Thoughts:
Better than ASUS P5Q and cheaper. Easy set up and fast. Gripes: Mem check at POST too long - can't turn off. Fan control on SYS header non-exisitant - poor show these days when Winbond chip can do it all. Only one SYS fan too... ? Otherwise perfect.
22-09-2008, 05:41 PM
Junior Member
Potenza rep: 18
4coreDual-Sata2
__________________
The more I know, the more I know I don't know .....
22-09-2008, 07:17 PM
The one
Potenza rep: 10
LanceH thanks for reading our review.
23-09-2008, 08:25 PM
Junior Member
Potenza rep: 0
Like LanceH, I too upgraded to a P43R1600Twins - Non WiFi or 110db - though I did order it from my supplier.
Running it clocked solidly to 2.7ghz on my trusty old 1.8ghz E4300 from my 4CoreDual VSTA board.
I think it was your review that tipped it Bluetooth!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
